How to visialize a 'stock' line graph
  • October 1, 2020
  • 6 replies
  • 203 views
I would like to visualize the opening and end stock in one line. This means for example
Opening Stock Week 1: 100 (t = 1)
End Stock Week 1: 80 (t = 2)
Opening Stock Week 2: 120. (t = 2)
This means on the x-axis (t = 2) has 2 values 80 and 120. I would like to see this jump without creating dummy x-axis points which are very close to t = 2.
Is this possible?
Best answer by Anonymous
@Marc Wingender
Maybe you can also use the Bar Chart to display the difference per period. If it’s not (like in example) always 1-directional (going down), you could use color coding for each direction.
This is a stacked bar-chart where I made the base transparent (‘Closing Stock’ value in your example) and calculated the difference between ‘Opening’ and ‘Closing’.
Soon we’ll add the line option allowing you to add e.g. a safety stock line.
High Low chart using the Bar Chart
High Low chart using the upcoming Bar-Line Chart
For bar-line chart, see also: https://community.aimms.com/share-your-product-ideas-37/can-we-have-a-barchart-linechart-in-the-same-chart-311?postid=1912#post1912
  • October 1, 2020
Not sure if it would work for you, but if you create a parameter that is two dimensional:
pStockLevel( iPeriod, iOpeningOrClose )
where the second index is just an index for set with opening and close elements, you could put period and openingclose on the x-axis. However, they will be evenly spaced, not sure if that is what you want
  • October 1, 2020
Thanks Guido for your suggestion.
It is not the full solution yet, but this option visualizes the best so far
  • October 1, 2020
Hi @Marc Wingender ,
Can you share a visual/screen-capture of the result? As we do not have such a stock chart in stock, so curious to see how the suggestion of @gdiepen plays out for you. Can imagine others love to see it as well.
Thanks in advance.
  • October 2, 2020
This is an visualisaition of the stock graph now…
The dotted straight line is the safety stock
  • October 5, 2020
@Marc Wingender
  • October 8, 2020
Thanks Gertjan, for your suggestion. For now we wait for 4.76 and then decide if we want to move forwards using the combination of the bar and line chart.
