Is there a network object equivalent in WebUI?
  • July 15, 2019
  • 5 replies
  • 274 views
MathFour
AIMMS Partner
I need something in WebUI that is like the WinUI Network Object. The best I can find right now is the map widget - but what if my nodes aren't locations? Can I use the map widget then?
Sorry Bon, there is no network widget as of now and is not in the roadmap for the immediate future.
You can use the map widget if you can figure out a way to hide the background layer which is an svg object.
  • July 16, 2019
MathFour
AIMMS Partner
  • July 17, 2019
Thanks, @mohansx - that's what I'm doing.
My next question is about labels on the map. I'm going to start a new thread for it since it will apply to even earth maps.
  • July 17, 2019
@MathFour , can you share how you are hiding the background on the map widget ?
MathFour
AIMMS Partner
  • August 26, 2019
@mohansx,
In order to hide the map, you access the css selector img.olTileImage and set the property display to none.
This only hides the map, though. To hide the zoom controls, you set display to none with the div.olControlZoom selector.
But you'll still have the attribution, so you have to set the css property color on the selectors .olControlAttribution and .olControlAttribution a to whatever your background color is.
When those four selectors are set properly, you have a clean slate on which to have a network map.
BUT, you still can't get all the clicks and hovers that you can with WinUI. So unless you just want lines and arrows, this method isn't all that helpful.
So please PLEASE put this on the development road map.
Please.
Jess Es
  • Grand Master
  • August 26, 2019
@MathFour Thank you for sharing your current workaround - would you mind to create a new post with your product idea? It will be easier to vote and track there
