Label pie chart wedges
  • October 16, 2020
  • 179 views
I created a very simple pie chart using a parameter with one index with 2 elements, named “Actual and “Penalty”.
I was expected that the pie chart showed me the names “actual” and “penalty” inside the wedges, like shown in the article: https://documentation.aimms.com/webui/pie-chart-widget.html
I also tried an elementtextidentifier to the set I use, although I would expect this does not make sense since the element are already named.
I can’t find anything related in the pie diagram options or do I miss something?
Best answer by Anonymous
I think this is what you expect; I simply created the identifier that you described and it indeed shows Actual and Penalty (as you expect). So not sure why it does not work for you.
  • October 16, 2020
  • October 16, 2020
Hi Gertjan,
Thanks for the quick reply. This is exactly what I mean.
Hmm, perhaps my CSS file does something unexpected.
  • October 17, 2020
@Marc Wingender , if you add
      ?_aimms_only_asr=false
to the URL it will turn off all your custom CSS (in fact, it will turn off all Application Specific Resources). That could help as a quick test to see if there is possibly an issue in the AIMMS software or something custom you added.
