Lists with text aligned as "justify" inside a Text Widget on Web UI are not being displayed as expected
  • August 26, 2021
  • 223 views
Hello, I am using WebUI and I would like to create create a Side Panel that contains a generic List.
I order to do so, I have added a Text Widget to the Side Panel. Then, I tried to fill it through both the input field and by setting a string parameter as input.
For both approaches, the List actually displays a very unusual alignment to the left when “justified” is applied as “Text Alignment”.
Page Configuration:
Page View as a Side Panel:
My goal is to make it look closer to what is rendered in a web browser when the corresponding HTML code is loaded.
For example, the HTML code corresponding to those pictures above could be presented as:
<ul style="width: 20%">
<li style="text-align: justify">
<b>Excepteur:</b> sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum;
</li>
<b>Excepteur:</b> sint cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum;
</li>
<b>Excepteursint:</b> sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum;
</li>
<b>Excepteur:</b> sint a b c d cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
</li>
</ul>
The information displayed in a web browser keeps every first word correctly aligned to the left as shown below:
Question
Is there a proper way, or even a workaround, to get the rendered list in the output to look exactly like the HTML one?
Best answer by Pratap Kumble
Hi @jean.patrick ,
You can add the below custom CSS
.ql-snow .ql-editor ul, .ql-snow .ql-editor ol {
margin-left: 25px !important;
margin-right: 10px !important;
list-style-position: outside !important;
text-align: left !important;
Please adjust the margins as per your liking.
Do let us know if this works.
Pratap
  • August 27, 2021
Hi @jean.patrick ,
Pratap
Andrew
  • September 9, 2021
Hi @jean.patrick
Did Pratap’s answer help you with your solution?
Best
  • November 26, 2021
Thanks @Pratap Kumble
It worked perfectly!
Sorry for the delay
Best
