I have the following Gantt Chart (see Figure 1) that starts on the current date.
Figure 1
I would like to shift the tasks to the past by a “x” amount of minutes/hours, which is simple to do. Nevertheless, when I shift, I get the following chart (see Figure 2):
Figure 2
Notice that in Figure 2 some tasks stay over the the y axis. I would like the part that goes over the axis to stay behind it.
Any comments on this issue?
Many thanks!
Leonardo
Hi Leonardo!
That looks strange indeed. I was wondering whether you are aware of the 3 options that you can specify in the Gantt Chart tab of the Gantt Chart options editor. There is a reference time, a viewport start time and a viewport end time. Did you adjust these values too? If not, I would suggest to do so and to try out the effect.
Hope this helps,
Mischa
@Leonardo Salsano de Assis , do the overlaid jobs revert to normal if you refresh your page ?
