SidePanelOrder and WidgetOrder sets
  • January 14, 2020
  • 121 views
Hi AIMMS support!
I have noticed that for the Workflow Panel and for the Status Bar there are pre-declared sets for indication of the order of the workflow steps (webui::indexWorkflowOrder) and status bar messages (webui::indexApplicationExtension) respectively. But for the Side Panel and the Widget Action the developer needs to declare such a set (as a subset of integers) in each model. In my point of view it will be better to work with per-declared sets for all these objects, also makes it easier to copy sections between different models.
Are there plans to add these pre-declared sets for the workflow and status in the future releases?
Tanya
Best answer by Pratap Kumble
Hi @tbulavskaya,
We actually do have pre-declared index that can be used for Side Panel and Widget Actions as well -
webui::indexPageExtension
You can find this in the ExtensionOrder set (under the AIMMS WebUI library → Pages and Dialog Support → Public Workflow Support Declarations) which is a subset of the pre-declared set of Integers, with several indices:
  • indexWorkflowOrder, used to reference the number of Workflows,
  • indexNoOfPages: used to reference the number of pages or steps in each Workflow.
  • indexPageExtension: used to reference the number of page extension such as Page Actions, Side Panels and also Widget Actions.
  • indexApplicationExtension: used to reference the number of application extension such as Status Bar messages.
I did realize that the documentation does not reflect this. Working on correcting that.
Please let us know if this helped.
Pratap
  • January 14, 2020
Hi @tbulavskaya,
Pratap
  • January 14, 2020
Thanks Pratap, this is exactly what I was looking for!
