I have a string parameter as axis label for the X-axis and Y-axis of a bubblechart.
When I hover over the axis, I see this same string parameter as tooltip. Is there a way to have a tooltip different from the actual string parameter value? I tried XXX_Tooltips, but that doesn't seem to work (unsure if this works for string parameters at all).
thanks,
