Constraint with lagged index
  • Jun 7, 2024 5:29 AM UTC
  • 92 views
rahmat
Dear All,
In a model, I have a constraint as:
y(g,t) - z(g,t) = u(g,t) - u(g,t-1) forall (g,t)
All variable are binary variable. g is a set of generator unit and t is a set of time. How to implement this constraint in AIMMS if there a three generator units and the time periods (t) are 1,2, and 3. For the initial condition, generator units #1 and #2 are off-line prior to the first time period indicated by the value of u = 0 while generator unit #3 is online indicated by the value of u = 1.
Thank you.
Best answer by Chris Kuip
Hi Rahmat,
To refer to the previous period of the first planning period, I usually use a parameter with initial data.
So let
    iu(g) := data { '#1' : 0, '#2' : 0, '#3' : 1 } ;
Then I can use it in a constraint like:
     y(g,t) - z(g,t) =
     u(g,t) - if t = first( s_TimePeriods ) then iu(g) else u(g,t-1) endif
Hope this helps.
With kind regards,
Chris
Chris Kuip
  • Jun 7, 2024 5:55 AM UTC
Hi Rahmat,
So let
     y(g,t) - z(g,t) =
Hope this helps.
With kind regards,
Chris
rahmat
  • Ace
  • Jun 7, 2024 6:10 AM UTC
@Chris Kuip
Thank you for your very prompt reply. I’ll try this to the model.
Thank you.
