I have a parameter read from a CSV file. The first column contains the index list, and the other three columns contain the data. However, I need to use the second column as a second index to differentiate between each hour after the parameter is loaded. I was wondering how this can be done in AIMMS. Please note that using the second column as an index in the first place when I am reading the the CSV file is not viable due to other constraints. Please see the attached photo for a better understanding of the issue.
Thank you.
Be the first to reply!
