Foood Menu Optimization
  • Dec 16, 2024 2:26 AM UTC
  • 111 views
Hi, i have found the reason behind infeasibility, there were corrections to be made in one of the constraint. Thank you for helping me. I need further assistance on this, I will display my project here on what i have done.
  1. I have declare the ingredients and the foods lists.
  1. The sodium content is of the food, not of the ingredient. After declaring the ingredients, i am connecting the ingredients with the food that it belongs to (in parameter called as recipe):
Simple example, bread slice the ingredient not much, so its just bread slice. For tuna sandwich it is bread slice, tuna and mayonnaise i have tick across and i thought AIMMS can read the ingredients as the subset of the respective foods.
I find it somehow correct by the way AIMMS show this.
  1. Linking with the constraint
Callback the parameter “recipe” in one of the constraint as i am using Linear programming model to solve this problem. And the decision variable X includes (days, s-meals, food, ingredients, patients).
  1. The result im expecting should be somehow like below when i extract from AIMMS for respective patients:
  1. But what i obtained now is as per below:
Question: How come AIMMS cannot read the connected ingredients to the food it belongs?
Hi ​@Anne. To find out what is causing the issue, I think it would help if you could share your AIMMS project. Would it be possible to attach your project here, preferably after adding it to a zip file? You can also send it to our support by email if your project contains sensitive information.
  • Jan 13, 2025 5:55 AM UTC
Hi ​@Marcel Hunting can you provide me your email since my data is confidential. I will send my project to your email.
Hi ​@Anne. Please send it to support@aimms.com. We will treat it as confidential.
  • Jan 19, 2025 7:47 AM UTC
Hi ​@Marcel Hunting. I have sent an email to support@aimms.com. Let me know if you have received it for reviewing. Thank you for your guidance.
