How to perfrom complex calculation in AIMMS
  • May 24, 2024 3:59 AM UTC
  • 109 views
rahmat
Dear All,
I want to perform a complex calculation in AIMMS. For example, the given data is the impedance (Z) with Z = R + iX. In a constraint, the impedance must be transferred into admittance (Y) where Y = 1/Z.
Is there a method in AIMMS to do this?
Thank you very much.
Best answer by MarcelRoelofs
@rahmat
AIMMS does not support complex numbers per se. So any constraint over complex numbers need to be implemented as two constraints, one for the real and one for the imaginary part.
In this, you can use that Y = 1/Z = 1/(R+iX) = (R - iX)/(R^2 + X^2)
MarcelRoelofs
@rahmat
rahmat
  • Ace
  • Jun 7, 2024 5:14 AM UTC
@MarcelRoelofs
Thank you for the answer….
