Issue with Model Feasibility in CPOptimizer 22.1
  • Mar 26, 2025 1:41 PM UTC
  • 97 views
Dear community,
When I try to execute my model, I receive the following message:
Warning: After zero branches CPOptimizer 22.1 concluded that ModelObjective is infeasible.
I don’t understand what is causing this issue or how to resolve it.
I am aware that some parameters are currently unused, but they will be needed for future adjustments once this first part is working.
Does anyone have any insights on what might be going wrong and how I can fix it?
Best regards,
Louis
Hi ​@Serval2501. There is no X(g) that can be 1 and satisfy the constraints XX2, DistMin_Points and DistMin_Centres. You can see this as follows:
  1. Change the definition of the objective variable MaxResult into: sum( g, X(g) ).
  2. Deactivate constraint Max_NC by adding "| 0” to the index domain.
  3. Solve the model.
You will see that the objective value is 0, so the maximum value for sum( g, X(g) ) equals 0, which implies that none of the X(g) can be 1.
Note that constraint XX2 enforces that X(g) = X2(g) for all g, so you could replace X2 by X in your model, and delete X2 (unless XX2 contains a mistake).
The original definition of your model contains several min() terms which is quite "ugly” and makes the model nonlinear. The min( Dist_Centre(g), … ) term evaluates to Dist_Centre(g) because Dist_Points(g, g_bis) = 0 if g=g_bis, so in its current form you do not need the min() terms.
  3. Solve the model.
