Indexing a variable with an initial value or constraint
  • March 23, 2020
  • 575 views
Hi everyone.
I'm starting with Aimms, I have two questions
First
How can I index a variable with an initial value or constraint? .
For example
X (i) is the dependent variable of the set (for example 4 things) with index i.
And what I need is
X (1)> = 50
X (2) <= 250
Variable X {
    IndexDomain: i;
    Range: nonnegative;
Second
How can I implement or call benders decomposition modules, stochastic programming etc. inside the MainExecution procedure?
Thank you
Thanking you for your support.
@Manuel
#1. As your constraint as two signs (<= and >=), you will need to declare two constraints. Use single quotes to refer to individual elements in your set.
con1 with definition X(‘1’) >= 50
con2 with definition X(‘2’) <= 250
You can also extend this with the index, say you want X(2), X(3), X(4) to be <= 250 then
Constraint conIndex {
    IndexDomain: i|ord(i) >= 2 and ord(i) <= 4;
    Definition: X(i) <= 250
Ord is the function which returns the position of the element in the set. Here, I assume your set starts at 1 - {1, 2, 3, 4, 5 ..}
#2. You can look at these two examples for implementations of stochastic programming and bender’s decomposition in AIMMS.
https://www.aimms.com/english/developers/resources/examples/modeling-book-examples/power-system-expansion/
https://www.aimms.com/english/developers/resources/examples/functional-examples/stochastic-programming/
Note that MainExecution is just a procedure which is linked to a keyboard shortcut, you can create new procedures as well.
  • March 24, 2020
@Manuel
  • March 25, 2020
Thank you very much.
I'm going to check that.
Best regards.
@mohansx
