Modelling question - if then constraint
  • Jun 3, 2019 8:57 AM UTC
  • 1293 views
Dear Staff,
I would like your tips for an if-then constraint.
In particular, I have the following variables:
R, binary variable
P, continuous variable
Y, continuous variable
I have the following parameters:
A
B
The constraints I would like to write are the following:
1) if R=1 then P = A*Y
2) if R=0 then P = B*Y
I would like to know if it is possible to have a linear formulation without using indicator constraints.
Thank you,
Hi @Chibo ,
You can use a big M formulation as below to model your constraints. You will have 4 sets of constraints in total. Here, M is a sufficiently large number, you should select this value based on the values of A, B and maximum range of Y.
code:
P >= A*Y + (R-1)*M
P <= A*Y + (1-R)*M
P >= B*Y - R*M
P <= B*Y + R*M
When R = 1, these become
code:
P >= A*Y
P <= A*Y
P >= B*Y - M
P <= B*Y + M
1 and 2 will make P = A*Y. 3 and 4 will always be satisfied if the value of M is large enough.
Similarly, when R = 0 - 3 and 4 will make P = B*Y and 1 and 2 will be rendered redundant.
  • Jun 5, 2019 7:23 PM UTC
Hi @Chibo ,
code:
P >= A*Y + (R-1)*M
P <= A*Y + (1-R)*M
P >= B*Y - R*M
P <= B*Y + R*M
code:
P >= A*Y
P <= A*Y
P >= B*Y - M
P <= B*Y + M
  • Jun 6, 2019 11:01 AM UTC
thank you very much for your help and for these precious suggestions. It is very kind of you.
I will try to implement them!
