After building a deterministic model, I constructed the robust counterpart of the model. I defined an uncertain parameter and I called the GMP GenerateRobustCounterpart. The model seems to be running without errors,however, it does not provide any result. It seems like the variable (vAllcocationFlow) does not get filled. Can someone help me with this?
I attach you here the Solve function (1) and the uncertain parameter definition (2):
Thank you very much in advance!
