Governing an optimization capability: what we've learned
  • Nov 2, 2026 2:25 PM UTC
  • 6 views
Patrick
AIMMS moves much of the application lifecycle closer to the business. Modelers and planners can build, adapt and deploy decision-support apps themselves, work that traditionally sat with IT or Digital. That is a big part of the value, and it also raises a fair question we hear more and more: how do you govern a capability like this?
What follows is not the story of a single customer, nor a standard implementation plan that comes with a guarantee of success. It's a combined view drawn from what we've seen across our customer base: the practices our most successful customers share, the reasons other implementations stalled or were discontinued, and what we learn early in pre-sales about which organizations are set up to succeed.
We share it as input rather than a prescription. Every organization is structured differently, and you're the best judge of what matters now, what can wait, and what doesn't apply to you.
Who owns what: business and Digital
In mature organizations, the business owns the decision and Digital owns the platform, with a few shared areas in between. The split typically looks like this:
Area
Business (modelers, planning)
Digital
Notes
Model logic and math
Owns
Reviews against standards
The business is accountable for the answers
UI and end-user apps
Owns
Sets design standards
Built close to the users who rely on them
Data integration
Defines requirements
Owns pipelines and data quality
The most frequent failure point when unclear
Architecture
Consulted
Owns
A reference architecture defined once and reused
Deployment and release
Requests and tests
Owns the gate
A clear path from development to test to production
Cybersecurity and access
Consulted
Owns
Much of the infrastructure is handled by the AIMMS Cloud Platform
Support
First line: model and usage
Second line: platform and data
AIMMS provides third line
Product lifecycle and roadmap
Product Owner leads
Co-owns the platform roadmap
Reviewed jointly with AIMMS
Handling the shift in decision rights
When the business can build and deploy more of its own solutions, decision rights change. Organizations that handle this well make the new rights explicit rather than letting them emerge by accident:
  • An executive sponsor sets the mandate and resolves conflicts between the business and Digital.
  • A named Product or Platform Owner is accountable for the portfolio of models, not just one application.
  • Tiered guardrails give business teams freedom in development, while Digital controls promotion to production and integration with core systems. Speed and control can coexist.
  • A small Center of Excellence sets modeling standards, promotes reuse, and builds internal capability.
  • Models are embedded in decision forums. They feed S&OP and strategic planning directly, with agreed rules on when model output drives the decision.
For many organizations this is a cultural shift as much as a technical one. What works best is starting with one high-value decision, proving the outcome, and letting governance mature with the portfolio rather than designing it all upfront.
Where it goes wrong
We learn as much from implementations that stalled as from those that thrived. Four patterns come up again and again:
  • Single-champion dependency. One expert builds everything with no governance around them. When that person moves on, the model stalls and trust erodes.
  • Digital takes full ownership. The tool is treated like traditional IT development. The business loses agility, and the main advantage disappears.
  • No embedding in decisions. The models are technically sound but sit outside the planning cycle, so their output is interesting rather than acted upon.
  • Misaligned planning layers. S&OP and strategic planning work from different assumptions, so leadership trusts neither answer.
What successful customers have in common
Across industries and use cases, the customers who get the most from AIMMS tend to share these traits:
  • C-level support for the capability
  • Clear governance, with a Product or Platform Owner assigned
  • Clear decision-making processes, with AIMMS embedded in them
  • Alignment between S&OP and strategic planning teams
  • A shared understanding of the value the software generates
  • Trust in, and acceptance of, the output of mathematical models
  • Readiness to act on that output and make big decisions
  • Solutions that are easy to use, from data integration to UI
  • Co-development with AIMMS, as a partner rather than only a vendor
Let's keep learning together
This picture keeps evolving, and much of it comes from you. How have you organized ownership between your business teams and Digital? What worked, and what would you do differently? Share your experience in the comments. Your lessons may be exactly what another member needs.
If you'd like to talk through how this could apply to your organization, reach out to your AIMMS contact. We're happy to set up a working session or connect you with a peer customer who has made the same journey.
