Is it available? And if not, do you have a recommended workaround in the meantime?
Unfortunately, the lines are modeled as individual svg path's. Areas can only be filled if they can be described by a closed path, which is currently not the case. For this to happen we would have to reconsider the way the lines are rendered in a line chart.
You may use a BarChart instead. But we will take your feedback into account!
Is there a way to squish a barchart over a linechart in a way that it can LOOK like it did in WinUI?
Thanks
I moved this ticket to the Share Your Ideas forum, there where new ideas for our product can be 'dropped'.
https://community.aimms.com/share-your-product-ideas-customers-only-37/how-idea-submission-works-181
Today we announced in the Product Update that this will be available soon; we expect to make it available in the next release (4.74).
Hi
We had introduced a new BarLine Chart Widget type in October 2020 with 4.76 release.
With the recent released 4.85 version, we have our new Combination Chart Widget type that support multiple chart types like Column, Line, Area, Spline, Area Spline and Scatter.
Curious to know if you got a chance to try out our new Combination Chart Widget type.
Please leave your feedback and suggestions on this new widget type in this group.
WebUI Team.
