Almost all widgets offered by the AIMMS WebUI support tooltips. Currently, it is only possible to customize the static tooltips. So in for instance a Gantt chart, we can only customize the static tooltip which gives information about the task that is selected. When dragging a task, either the new start date or duration of the task is displayed. In some applications it might be more user-friendly to display the new end date of a task instead of displaying the duration.
Thanks for sharing your suggestion, Colin! I agree, there is even more potential in tooltips. It would be nice to hear if others ran into this...maybe some other use cases where more options to customizing the tooltip might have helped?
Updated idea status Discussion ongoingON ROADMAP
@ColinLodewijks it is possible to create a custom tooltip that is dependent to tasks and its task duration.
Please let me know if you were not able to do so. Here are a couple of documentations that can help you with that.
For now this Idea will be Declined since it is possible to be developed.
On BacklogDeclined
