On Backlog
Always show library prefix in WebUI widget identifier specification
Related products:WebUI
  • Dec 7, 2021 10:00 AM UTC
  • 74 views
sandervlot
AIMMS Partner
Hi, in the AIMMS models I’m working with, the parameter name + index domain is typically too large to keep showing the library prefix in the WebUI identifier specification.
I would like to see the library prefix always, to avoid picking the wrong identifier. Even if that means that I can see less of the par name and index domain (I don’t think I really need to see the index domain in this screen). Can you consider adding this functionality to AIMMS?
Madhu Krishnappa
Updated idea statusNew→On Backlog
Hi @sandervlot!
Just tested this, and it is working as you wanted! Now you can either only search by the name or you can add the prefix too. See this example:
Can you confirm this is what you expected?
sandervlot
AIMMS Partner
  • Mar 1, 2024 12:00 PM UTC
Hi Gabi, can you check with longer parameter names? My request was specifically for parameters with longer names. In those cases, the library prefix falls off the screen.
Hi, indeed:
I’ll add this to our backlog.
