Declined
Clear Filters via procedure
Related products:WebUI
  • Jun 15, 2023 8:06 PM UTC
  • 5 replies
  • 70 views
MattC
A lot of times, users will add many filters to a table/widget, but they will then want to clear all filters from all widgets. It would be great to have an AIMMS procedure/function that could clear these filters via a button.
Jess Es
  • Grand Master
  • Sep 26, 2023 8:10 AM UTC
Hi @MattC, we would love to find out more about this idea. Could you give us a bit more detail about specific cases you have run into? Thanks!
(You can post here or feel free to reach out directly to @Madhu Krishnappa )
Jess Es
  • Grand Master
  • Sep 26, 2023 8:11 AM UTC
New→Discussion ongoing
Hi @MattC,
Can you share a little more of your use case? What type of filters you want to empty? If it is the native AIMMS filters on Table Widget, the ‘Clear All Filters’ button is available. If you have Multiselect Widgets as your filters, my advice is to create a procedure to either set the binary parameter used as filter to 1 or 0, and then add it to a button. You can add this button either on an item action, a button, a status bar, depends to how your application is.
Let me know if this helps!
@MattC I’ll decline this ‘Idea’ for now since we do have a couple workarounds for you. Please let me know if you have any further questions.
Discussion ongoing→Declined
