Implemented
In-cell Data Bars in WebUI tables
Related products:WebUI
  • September 29, 2023
  • 125 views
Could we add gradient progress bars like excel has in the webui tables. Something that would look like this:
There is an example of doing this at the following stack-overflow site:
https://stackoverflow.com/questions/4132880/in-cell-data-bars-in-jqgrid-possible-or-not/4133016#4133016
New→Discussion ongoing
Discussion ongoing→On Backlog
luispinto
  • Customer Success Manager
  • June 11, 2024
Dear @tjokes1
We recently released a new feature in AIMMS that allows you to include html into table cells:
https://documentation.aimms.com/webui/widget-options.html#webui-ishtml
With this you can generate html code to make the same bars as you are showing in your screenshots.
Here is an example:
To achieve this I did the following:
  1. Created a string parameter to hold the html with the necessary indexes
  2. Add the html code that I wanted to use. In this case, I used this:
StringParameter sp_barChart {
IndexDomain: (i_index1,i_index2);
Definition: {
if p_productionValues(i_index1,i_index2) then
formatString("
<div class=\"container%s\">
<div class=\"bar%s\"></div>
<div class=\"label%s\">%n%%</div>
</div>
<style>
.container%s {
width: 60px;
height: 20px;
background-color: white;
border: 1px solid #000;
position: relative;
.bar%s {
width: %n%%;
height: 100%%;
background-color: green;
position: absolute;
top: 0;
left: 0;
.label%s {
position: absolute;
top: 50%%;
left: 50%%;
transform: translate(-50%%, -50%%);
font-family: Arial, sans-serif;
font-size: 16px;
color: black;
</style>",
(i_index1 + "" + i_index2),
round(p_productionValues(i_index1,i_index2)/$p_max_p_productionValues*100,0),
(i_index1+ "" + i_index2),
endif;
webui::IsHtml: True;
If I am honest my code is messy and not very nice, but I hope it illustrates the idea.
You can/should move the css to somewhere else, but to keep it simple, I left in the html.
With this new HTML feature, you can do a lot of modifications and create complex, meaningful interfaces.
Hope it helps.
On Backlog→Implemented
