Implemented
WebUI larger dialog pages
Related products:WebUI
  • Jul 4, 2019 11:23 AM UTC
  • 7 replies
  • 191 views
sandervlot
AIMMS Partner
I would like to be able to make larger dialog pages than is currently possible in the AIMMS WebUI.
One use case as an example:
Currently I'm working on Schedule Compare functionality, that (ideally) would be an overlay screen on top of the current Gantt Chart page. The overlay would then contain 2 Gantt Charts (before and after, so to say). Unfortunately the largest available dialog page is too small to properly show 2 Gantt Charts.
  • Jan 31, 2020 11:00 AM UTC
Aimms, any updates on this?
My customer is also looking for bigger dialog pages.
@AIMMS User Support same question. Is there no way to put a decent size table on a dialog page without having to scroll for data with more than 5 lines? Added a (blanked) screenshot below.
Thanks
  • Feb 3, 2020 4:33 PM UTC
Hello @MarianneWilde,
At this moment, the sizes of the Dialogs are ‘fixed’ and, to be honest, I am slightly confused by your picture. See below an example of a Dialog; it has 13 rows, plus headers etc. Are you sure you used the max space for the table?
It sure seems your table can be made higher (max 3 rows high, 8 columns wide). If this is due to the Selectors on top; I would suggest to move those to the side so you can have full height of the table in your page and the selectors on the right; similar to what I did below with Scalars.
Large Dialog with Table (developer view)
You could decide to play with the default row height (in miscellaneous options of the table); default = 3, smallest is 1 (see below)
Large Dialog with Table with Row Height reduced to 1 (developer view)
BTW: You might have seen in the product update of December that we are working on a new Page Layout setup; if not, see https://community.aimms.com/product-updates-roadmap-customers-only-36/product-update-december-2019-485. This setup will allow to ‘auto-filling’ the complete space appointed to table (we will go away from column and row height for widgets which e.g. leads to unnatural breaks at times).
Hope this helps.
Jess Es
  • Grand Master
  • Feb 5, 2020 11:36 PM UTC
Now I’m curious what is your use case also, @OlmoVerhagen ?
  • Apr 14, 2021 8:24 PM UTC
Check out the preview of the next feature release:
With custom sizing and the new grid layout, you will have the ability to create a better experience when using DialogPages.
  • May 3, 2021 12:54 PM UTC
Updated idea status Discussion ongoing → In Development
  • Aug 24, 2021 7:21 AM UTC
Updated idea statusIn Development→Implemented
Implement and available since AIMMS Version 4.80.
