Declined
WebUI Table download .csv and .xlsx column names
Related products:WebUI
  • Feb 16, 2024 1:12 PM UTC
  • 60 views
The column names when downloading the .xlsx file from a table in the WebUI are different when downloading the .csv file. The .xlsx file contains the identifier names, whereas the .csv file contains the text of the element parameter, which I think is better. One way or another, the column names are not consistent with each other, could you have a look at this minor problem?
Kind regards and thanks in advance,
Martijn
New→Discussion ongoing
Hi Martjin!
What do you mean by the columns are not consistent to each other? The .csv and .xlsx exports are indeed different. The .csv you can expect the raw content, then no translations will be exported. The native .xlsx export will export the exact view of your table. If you prefer both being the same, you can create a custom .csv export with the translations or new exports without the translations for .xlsx.
This article will important if you want to hide only one or the other native exports: https://how-to.aimms.com/Articles/568/568-disable-standard-webui-functions.html
Discussion ongoing→Declined
