Question
How to detect 'empty' keys when read parquet file using dex mapping
  • January 26, 2026
  • 12 views
Dear Community,
I’m using the following dex mapping :
<AimmsParquetMapping>
    <RowMapping name="xxx">
    <ColumnMapping name="A" binds-to="iA" binds-existing="1" skip-non-existing="0"/>
    <ColumnMapping name="B" binds-to="iB"/>
     <ColumnMapping name="C" maps-to="plan(iA,iB)"/>
    </RowMapping>
</AimmsParquetMapping>
Suppose now I have a row in the input file that has a NULL for the iA value. I would expect an error when reading the file, since NULL is not in the set, but the line just got skipped. Is there something wrong here or is there another way to detect empty key values?
Kind regards,
Marc
Using DEX version: 25.6.1.1
  • Ace
  • January 26, 2026
Hi Marc, does using skip-non-existing="2" help in your case? Not sure if you have tried this already.
A value of 2 will skip the value, but will also issue a warning. You can use this attribute to skip objects or rows that are indexed by empty labels in the data file, but also by non-empty labels that cannot be added to e.g. a defined set in the model.
  • January 27, 2026
Hi Joost, yes I also tried value of ‘2’, but with same outcome
