How to import data from Databricks into AIMMS?
  • April 30, 2024
  • 96 views
luiswilbert
Dear
I want to import data to AIMMS from Databricks. when I import data to Power BI, we are using the following strings:
could you help me to configure AIMMS to import the data ?
Thanks
Best answer by RoxannaBindenga
Hi Luis,
Thanks for reaching out. Recently @Vincent built a notebook template for the other way around (getting data from AIMMS into Databricks). I can share this Notebook with you in hope it helps you in the right direction. Can you tell me which email address I can send it to?
You’ll need SAS-tokens for the authentication - if you’re using a regular cloud (as opposed to an SCNavigator cloud) you can use our datalake toolkit to create them.
RoxannaBindenga
Hi Luis,
RoxannaBindenga
You can send me an email on roxanna.bindenga@aimms.com btw :) so you don’t have to share an email address on this forum.
