Extracting an index from a variable
  • September 11, 2024
  • 30 views
t = time index
M = vehicle index
I = supply node
J = intermodal node
I have a variable with (t,M,I,J) index which determines the number of units delivered to a specific node. However, I want to determine the time of delivery of each set of units as a separate variable. Thus, it’s like extracting t from the variables (t,M,I,J). How do I approach this?
Thaank you!
Best answer by gabiservidone
Hey @ccfcuento, depends a little on what is your final objective and how you have set the variable domain for these indexes.
If t is unique for M,I,J, then you can use something like:
ep_uniqueT(i1, i2, i3) := first(it | p_complete(i1, i2, i3, it));
If not, you can use:
ep_multipleT(i1, i2, i3, it) := it $ p_complete(i1, i2, i3, it);
Attached the section I created this example, you can add it to your model by importing it: https://how-to.aimms.com/Articles/145/145-import-export-section.html#importing-a-section
  • 212 replies
  • September 18, 2024
