How to select the maximum and minimum value of a variable
  • 12 September 2022
  • 135 views
Userlevel 1
Badge +4
Good day All,
I have a variable PW(t) where t is index from 1 to 24. What is the command to select the maximum and minimum value of PW(t) and also obtain its average.
Thank you.
Best answer by gabiservidone 12 September 2022, 16:51
Badge +6
I recreated your use case with random numbers as follows.
Now, to find maximum, minimum and average, I used these functions.
And the results are:
p_min is 2.
p_max is 99.
p_avg and p_mean are 53.
If you want the element inside t that has the minimum/maximum value, you need to use these functions:
Userlevel 1
Badge +4
Thank you for this.
Please which of the Identifiers did you use in picture 2 and 3. Do I have to create p_min, p_max, p_mean and p_avg as variables or parameter? You may kindly share the file to aid my understanding. I am new to AIMMS. Please note PW(t) is a variable that is obtained after running the model.
Thank you once again.
