My model took more than 14 days to run on i7 core computer with 16GB RAM. And it still does not give an optimal solution yet. What will happen if we stop AIMMS during the middle of running a model when the solution is not optimal yet?
The gap in progress window shows 38.2% for 10 days (see attached picture), then it drops to 38.1% on day-13. From what I understand, the gap is the difference between a best known solution and the best bound. If I set the gap to certain values, which part of the model will be affected? Will all the constraints be satisfied/evaluate? Or will AIMMS only satisfied half of the constraints? For your information, my objective is to maximize the preferences of the lecturer. My preferences parameter has the range values from 1 to 5, where 1 is least preferred while 5 is the most preferred.
Can anyone help me? Thank you in advance!
