Subtraction of Element Valued Expressions
  • May 29, 2019 4:45 AM UTC
  • 9 replies
  • 295 views
Hi! I have a constraint (shown at the photo below) wherein two sets need to be subtracted. I tried introducing another set Kw with a definition of k-Ks but it says subtraction of element valued expressions require the set range to be equal, but the ranges domain set "Subblock" and set "Candidate_Subblocks" differ.
Identifier: Subblock
Index: k
Identifier: Candidate_Subblock
Index: Ks
Identifier: Subblock_Difference
Subset of: Subblock, Candidate_Subblocks
Index: Kw
Definition: k-Ks
above is the current code I have. Do you have any Idea on how I can code my constraint?
Best answer by deannezhang
Making both Candidate_Subblock and Subblock_Difference as a subset of Subblock and change the definition of Subblock_Difference like below should work.
Index: k
Subset of: Subblock
Index: Ks
Subset of: Subblock
Index: Kw
Definition: Subblock - Candidate_Subblock
deannezhang
  • May 29, 2019 10:37 AM UTC
Index: k
Subset of: Subblock
Index: Ks
Subset of: Subblock
Index: Kw
  • Newcomer
  • May 29, 2019 11:06 AM UTC
Thank you so much! It worked! Now my constraint will be written
sum(Kw, x(v,k))=0
or
sum[(k|Kw, x(v,k))] = 0
deannezhang
  • May 30, 2019 1:36 PM UTC
sum(Kw, x(v,kw))=0 will work.
you can use the index of the subset so it will only apply those elements in the subset.
  • Newcomer
  • May 30, 2019 1:42 PM UTC
Thank you! I have one last question,
how do I code constraint 7 and 9? Cause I’m not quite sure with the “:” in it. Sorry! Thank you
deannezhang
  • May 30, 2019 2:03 PM UTC
what does ": " mean?
  • Newcomer
  • May 30, 2019 2:36 PM UTC
it’s “for which”
deannezhang
  • May 30, 2019 3:03 PM UTC
😂care for some more explanation on the meaning of the constraint and index? otherwise, I do not know how to help here.
  • Newcomer
  • May 30, 2019 3:13 PM UTC
Constraint 7:
YL(k,t) - Binary Variable(set to 1 if subblock k executes loading activity in period t)
x(v,k) - Binary variable(1 if subblock K is reserved for vessel V)
Tv - subset of period/s when vessel v loads or unloads containers
constraint 7: denotes whether a subblock performs a loading/unloading activity
deannezhang
  • May 31, 2019 12:48 AM UTC
If Tv is input, which means it does not change depending on variables, what you can do is to introduce parameter As Tv. For example, Valid_v_t(v,t) is 1 if vessel v can load/unload at time t. then (7) can be something like
Identifier: constraint7
index domain: (k,t)
definition: gamma(k,t) = sum(v|Valid_v_t(v,t) , x(v,k))
