Using a parameter as index (nested indexes)
  • July 7, 2021
  • 167 views
Hi all,
I’m sorry of the question is too basic, but I recently had to re-run an old code (originally developed in AIMMS 4.47) and I’m having lots of trouble correcting errors.
I have a variable ( Ireal(ld) ) that uses another variable ( Vreal(bus,ph) ) in its calculation.
I have an string parameter ( load_bus(ld) ) that has the “bus” value for each “ld” and a parameter ( load_ph(ld) ) that has the “ph” value for each “ld”.
In  the old code I used Vreal(load_bus(ld), load_ph(ld)) to calculate the Ireal(ld), but in the new AIMMS version (4.88) I keep getting “The scope of string parameter “load_bus” has not been specified”.
Can anybody please help me in what I’m missing?
Thank you in advance.
Best answer by Chris Kuip
Hello mglopes,
You can define element parameters
  • ep_load_bus(id) with range bus and definition StringToElement(bus,load_bus(id))
  • ep_load_ph(id) with range ph and definition StringToElement(ph,load_ph(id))
Next you use these element parameters as follows:
Vreal( ep_load_bus(id), ep_load_ph( id) ).
Hope this helps,
Chris
Chris Kuip
  • July 8, 2021
Hello mglopes,
Hope this helps,
Chris
