SC Navigator 24.1.1
Related products:SC Navigator
  • Jan 16, 2024 12:08 PM UTC
  • 44 views
SC Navigator 24.1.1
Date January 11, 2024
  • New Features
    • Risk Analysis simulates closing each location, one at a time, and assesses the corresponding impact. This will help you in finding the vulnerabilities of your supply chain. More information about the Risk Analysis can be found in the documentation: Risk Analysis.
    • With Trade-Off Analysis you can do multiple solves, each with a different setup, and find the best trade-off between your KPIs. More information about the Trade-Off Analysis can be found in the documentation: Trade-Off Analysis.
  • Improvements
    • Previously, some pages displayed raw coding names instead of proper text. These have now been replaced with appropriate texts across all pages.
    • The pages "Geocodes" and "Distance" are now also available when the data is loaded from a dataset. In that case, the data on these pages is read-only.
    • The icons for the primary page actions on page "Geocodes" and "Distance", have been replaced by icons that match the action, instead of the generic AIMMS logo.
    • Links to the latest e-learning material have been added to the template.
    • Solving time for datasets with Single Sourcing data is decreased in case of both active and relaxed optimization options.
    • The SC Navigator version numbering has changed. From now on, the first number will refer to the year in which the version was released. The second number still increases with every feature release. The third number increases for bug fix releases.
  • Bug Fixes
    • The data validation warning that appeared when a minimum number of Suppliers/Productions/Warehouses/Locations was provided without a maximum, is removed.
    • When a results scenario was saved right after a Full Solution Export, the scenario did not appear in the list of results scenarios.
