SC Navigator 24.13.1
Related products:SC Navigator
Date November 26, 2024
  • New Features
    • The user experience for scenario planning in SC Navigator has undergone a significant overhaul. Key enhancements include a more intuitive layout for Scenario, Network Scenario, and Batch Optimization pages, a streamlined process for creating scenarios, improved visibility of scenario contents, and the ability to edit scenarios, among other upgrades. These improvements aim to simplify scenario planning, boosting user efficiency. Read more about the new Scenario, Network Scenario, and Batch Optimization functionality in our documentation.
  • Bug Fixes
    • Transport ratios specified for a period group (a regular group, not a curly bracket group) in the 'Period 2' column of sheet Transport Ratio, were not disaggregated correctly to all periods in that group.
    • In the Load Data dialog page, you can click on Upload Excel File and then cancel the Excel file selection. If after that, you would load a dataset, a data issue was falsely raised about the file not having been read correctly.
    • On page Control Panel, several column headers in the tables have been updated to match with the corresponding attribute names.
    • On the KPI Results dialog page, the label Weight Factor has been renamed to Scaling Factor.
    • On the KPI Results dialog page, the tables only showed data for the active scenario, not for the compared one(s).
    • After loading a dataset, the warning "Attribute names have been replaced with newer names." no longer occurs. This warning will only occur in combination with loading an Excel template.
    • On page Results - Transport, The highlighting in the Transport Ratio Results table didn't work when the data was close to the minimum or maximum value.
    • If you unselected some warehouses on the Warehouse filter, that will also unselect the products that are only used by those warehouses on the Product filter. In that case the Product filter is now also marked as 'filtered'.
    • Previously, when uploading files larger than 128 MB, SC Navigator would become unresponsive. Now you will get an error message indicating the maximum file size has been exceeded.
    • The contents of the file "parquet-results-definition.xlsx" is now consistent with the generated files.
