SC Navigator 24.5.1
Related products:SC Navigator
  • May 22, 2024
  • 30 views
SC Navigator 24.5.1
Date May 21, 2024
  • New Features
    • Ratio constraints have been added for Suppliers, Productions, Warehouses, and Transport Lanes, allowing the SC Navigator optimization model to capture business rules better. You can use this feature via the new sheets in the template: Supplier Ratio, Production Routing Ratio, Warehouse Ratio, and Transport Ratio. You can read more about Ratio Constraint Attributes in the SC Navigator documentation.
    • A new attribute ‘Maximum Road Distance To Retrieve’ can now be specified for any transport mode on the ‘Mode of Transport’ sheet in the template. As a result, when retrieving road distance data, if a lane is using a mode of transport for which Maximum Road Distance To Retrieve has been specified and the straight line distance for that lane is greater than the Maximum Road Distance To Retrieve, then the distance is not retrieved and the straight line distance will be used for that lane.
    • Next to the Trade-Off Analysis that we introduced earlier this year, you can now also do a Center of Gravity Trade-Off Analysis. You can do this on the new Center of Gravity sub page ‘CoG Trade-Off’. You can set up and run multiple Center of Gravity runs here. During the runs the user can continue the work at other parts of SC Navigator and can return to check the results when the runs are ready. For more information, please read Center of Gravity Trade-Off Analysis in the documentation.
  • Improvements
    • A new data validation warning has been introduced to indicate whether the roundtrip attribute is used for lanes other than inter-resource lanes.
    • The behavior of Download Solution on the Save Results Data dialog has changed. Previously, it would only export the current data to an Excel file. However, in the new version you can export multiple results datasets to a single Excel file. You can read in the documentation how to use Download Solution for downloading multiple results datasets.
    • You can now also filter data in tables on dialog pages. For instance, this allows you to use filtering when trying to select an input or results dataset.
  • Bug Fixes
    • On page Trade-off Analysis, the selected secondary y-axis was not saved into the Trade-Off Analysis Results Datasets, so when the saved data was loaded, the secondary y-axis was not initialized properly.
    • On page Center of Gravity, for the Cost Breakdown widget, the bar colors are now consistent with the legend colors.
    • The validation logic for country codes (on the Location sheet) now checks both the “Country” and “Country Code” columns to ensure data integrity. Previously, it only checked the ‘Country’ column.
    • If one or more of the following attributes on the Location sheet contained only empty spaces: “Street”, “City”, “Postal Code”, “State”, or “Country”, the generated geo coordinates could not be saved to the database.
    • On page Results - End To End, the table contained a column called ‘Warehouse’. This column is now correctly named ‘Production’.
    • The playback action of the period slider could sometimes skip periods.
    • The element ‘cts_e2e_dummy’ was included in the “End to End Report”. This is an internally generated element that should not have been included in that report.
    • Uploading an Excel template with extensive data in the Supplier Product sheet could be extremely slow.
    • We have adjusted an internal solver setting to improve the performance. However, in the unlikely situation that this change negatively impacts the performance, please contact us for assistance.
    • Previously, exporting CoGs to the SC Navigator dataset would assign excessive transportation cost data. Now, when exporting CoGs, they will inherit the relevant transportation cost data from their associated location group.
