SC Navigator 24.7.1
Related products:SC Navigator
  • June 24, 2024
  • 26 views
SC Navigator 24.7.1
Date June 24, 2024
  • New Features
    • The ‘CoG’ and the ‘CoG Trade-Off’ functionalities have been extended with the ability to do a Constrained CoG. The Constrained CoG allows you to perform CoG calculations, but it can include capacity constraints on the number of CoGs, the new CoG throughput, the existing Warehouses, and the existing Suppliers. Please know that a constrained CoG model is a simplified model to determine potential warehouse locations, and you are advised to run the generated CoG solution through the full SC Navigator model. More information on Constrained CoG can be found in the documentation.
    • From now on, Scenario Batch runs can be run in parallel in the background, allowing the user to use other features of the software while waiting for the results of the Batch Run. The number of concurrent solver sessions in your license will determine how many solves can be run in parallel. Please contact your account manager if you would like to increase the number of concurrent solver sessions.
  • Improvements
    • On page Data - Manage Data, a new column (# Results) has been added to the tables Input Datasets and Scenarios, so that you can see the number of Results datasets that are build on top of this dataset/scenario.
    • On page Data - Manage Data, the Results table did not show Results Dataset that somebody else created, but did not share. They are now all shown, so that they can be deleted if needed.
    • On page Results - Transport, the ‘Number of Trips’ column is added to the ‘Primary Transportation’, ‘Secondary Transportation’, ‘Direct Transportation’, and ‘InterResource Transportation’ tables. The number of trips is calculated based on the volume and the average load size.
    • On page Control Panel, in the Model Control table, the ‘Optimality Gap for Optimization’ value is now shown with all digits in the tooltip.
  • Bug Fixes
    • On pages Results - ‘Cost to Serve’ and ‘End To End’, the ‘Customer Revenue’ was the average revenue (by period) instead of the actual revenue.
    • An “-” in the name of a custom objective could lead to a situation where the custom objective was not calculated at all.
    • The Product Filter on production-related pages did not include all the production-related products. This issue also had an effect on the maps showing Production locations. Production locations with all products unselected were still shown on the map, and the volume shown on the tooltip of the Production location was not correct.
    • It is now possible to download the template from the Whiteboard without location data (a warning will be given instead of a fatal error). This makes it possible to make use of Excel while providing the location data.
    • On page Results - Transport, the Volume by Mode of Transport chart showed all transport modes instead of only the available ones.
    • During the development of CoG Trade-Off some bugs appeared in the normal Trade-Off Analysis which are now fixed.
