SC Navigator 24.9.1
Date July 30, 2024
New Features
If the model has Data Separation and the user is connected to multiple business units/groups, SC Navigator will now show a new item (Business Unit) on the status bar. Users can switch between their different groups using this item.
Improvements
We have improved the loading of results, for results saved in this version.
The results of the selected CoG Trade-Off Analysis runs can now be exported.
In “System Configuration”, we have removed the “Conversion to Data Lake” page as it is no longer needed. Additionally, the ability to change the data source by clicking on the status bar “Data Source” item has been disabled.
A new option has been added to the Whiteboard Edit Node Info dialog, allowing users to disable the creation of groups for nodes that contain a single Supplier, Production, Warehouse, or Customer.
The exported parquet files have new attributes names going forward, to allow for better support by data platforms like BigQuery and Databricks. The new attributes are all lower case letters (a-z) and underscores, so no more spaces and parentheses. In the generated input definition file “Parquet File Definition SC Navigator.xlsx” (see Download Parquet File Structure) and the generated output definition file “parquet-results-definition.xlsx”, both the old and the new attribute names are present. SC Navigator input parquet files support both names right now, while output files will only use the new names.
Bug Fixes
When running Trade-Off Analysis or CoG Trade-Off Analysis simultaneously with a Location Risk Analysis, the error message: “awf.data.aimms.session: There already exists a file or directory named…” will no longer appear.
