SC Navigator 25.10.1
Related products:SC Navigator
  • June 30, 2025
  • 17 views
Date June 30, 2025
  • New Features
    • A new feature “Lead Time Offsets” is added to SC Navigator. You can now define a “Period Offset” at key supply chain steps — Supply, Production, and Transport — to model lead time offsets. More information can be found in the section Lead Time Offsets.
  • Improvements
    • The algorithm to solve CoG using “Max Drive Time” and “Constrained CoG” (when the objective is to minimize the number of CoGs) has been improved. The algorithm should now get a faster solution or get a solution with a smaller gap.
  • Bug Fixes
    • The violation related to Type Count was not shown in the infeasibility analysis.
    • A data validation error is raised if a base case lane routes a product from a source location that does not support it.
    • The Windows notification that informs that all optimization runs have finished, always appeared after running a Scenarios Batch Run, even though ‘Allow notifications’ was not checked in the Control Panel.
    • The Cost To Serve calculation has been corrected for certain cases when both a warehouse and a production were in use at the same location. For example, previously in certain situations, there were products for which the production volume reported by the Cost To Serve was negative if there was inventory for them at the same warehouse location.
    • The community link on the SC Navigator page in the documentation now correctly refers to the AIMMS Community again.
