SC Navigator 25.14.1
Related products:SC Navigator
  • September 18, 2025
  • 20 views
Date September 18, 2025
  • New Features
    • On page Transport Navigator Results, a new tab is added: Route Distribution. It provides interactive histograms and a detailed data table for analyzing route performance. Users can filter by interval, view tooltips with route details, and compare attributes side by side.
  • Improvements
    • Transport Navigator can now handle demand data that exceeds vehicle capacities, enabling multiple shipments to fulfill customer demand.
    • Page loading speed is improved among CoG pages. The improvement is noticeable when working with certain larger datasets, while smaller datasets may see less impact.
    • The performance of the algorithm to solve Center of Gravity using “Max Drive Time” and “Constrained CoG” (when the objective is to minimize the number of CoGs) has been improved for some cases, along with the performance of the “Speed” option for the Number of CoGs algorithm.
    • On page Center of Gravity, on the Node side panel, nodes of type CoG can now be (un)selected in Filter by Node Type.
    • On both page Center of Gravity and page CoG Run Details, the CoG side panel is added. This allows you to filter on individual CoG nodes.
    • On page CoG Run Details, the Customer Location side panel is also added.
    • On page Results - Cost To Serve, Customer, Period and Product Groups have been added to the side panel.
    • The Clear All Filters widget action has been added to multiple side panels.
    • A warning is given before deleting all customizations when selecting Reset Map to Default.
    • Labels and texts are updated in the UI for consistency.
    • The documentation was updated to be more consistent with the app.
    • On pages Results - Cost To Serve, and Results - End To End, the Period filter now works independently from the other Results pages.
  • Bug Fixes
    • The Number of Trips was not calculated when a Rate Card Drop Size was defined on either the Customer sheet or the Location Product sheet.
    • In Transport Navigator, the solver ignored the Grouping Codes specified by the user. Now, the solver does take into account the Grouping Codes and they have been added to the Route Details, Route Summary and Vehicle Summary tabs.
    • In Scenario Navigator, for Custom Objectives, the attributes Maximum Allowed and Minimum Required were not correctly used when solving the model.
