SC Navigator 25.4.1
Related products:SC Navigator
  • Feb 10, 2025 11:36 AM UTC
  • 31 views
SC Navigator 25.4.1
Date February 10, 2025
  • New Features
    • The model has been extended with the ability to create a Power BI Embedded report, based on the data in the application. This is available as an extra module, please contact your account manager for more information.
  • Improvements
    • The exported results are also used in the new Power BI Embedded feature and therefore, the results have been extended with the sheet/files with the element description as well as the sheet/files with the group definitions. Also the following attributes have been added:
      • Start Date and End Date to Period Definition/period-definition,
      • Longitude and Latitude to Location Definition/location-definition,
      • IsSKU, IsUnion, and IsIntersection to Product Definition/product-definition.
    • The fields “adopted” and “active” in the _dataset_info.parquet file were written as int32. However, if the cell was empty, pandas would interpret this as NaN (Not a Number) and therefore as float. This lead to a situation, where the model was no longer consistent with the file specification. From now on, the model will actually write 0 to prevent this issue.
  • Bug Fixes
    • When using Bill of Materials that create two or more products, the Cost To Serve and End to End reports were incorrect.
    • On page Control Panel for the table Min/Max Constraints, the Show All Attributes action was not working properly.
    • In some cases, the constraint “Max # of Sources for Customers” in combination with product groups could result in an infeasible model.
