SC Navigator 25.2.1
Date January 16, 2025
New Features
For (almost) all tables on all the Data pages, a new action is available in the three dots menu (top right corner of each table): Show All Attributes. This action allows you to view and edit all available columns/attributes, even if they currently contain no data. You can hide the columns without data, by using the action Only Show Attributes With Data.
Improvements
The Release information dialog that shows up the first time you start a new version of SC Navigator, has an improved look and now shows all the release notes of all previous SC Navigator versions, just like the Release Notes page in our documentation.
The data validation for rate cards was inefficient. The code has been modified to speed up this process.
Bug Fixes
The calculated rate card cost could be wrong if you used a Rate Cards UOM that was different from Default/Base UOM, in combination with rate card attributes Cost Per Distance, Cost Per Trip, or Minimum Cost Per Trip. If you use this combination in your model, please contact us at support@aimms.com.
