SC Navigator 25.6.1
Date March 24, 2025
New Features
SC Navigator now offers SC Navigator ETL, a tool that automates data preparation via Microsoft Azure Data Factory by pushing transformed data into the application and eliminating the need for users to import Excel files or configure the REST API connection. This is available as an add-on module; please contact your account manager for more information.
The results of the data validation are now stored when saving an input dataset. The stored data validation results will be read in when loading that dataset, instead of re-executing the data validation logic. This improves the performance of loading a dataset, especially when data validation takes some time. A result of this change is that a new column “data_validation_version” is added to file “_dataset_info.parquet”. This value can be left 0 when you upload your dataset directly to the Azure Data Lake.
Improvements
On page Power BI, the styling of the Edit/View Mode dropdown list has been improved, such that it no longer looks read-only.
As part of an improvement to the UI and UX of the AIMMS WebUI, the two main font families, Roboto and Montserrat, have been replaced with Inter Variable.
Bug Fixes
When using the Customer filter, deselecting individual customers from different groups unintentionally removed all customer locations.
The Warehouse filter was missing two widget actions (Switch to Location View, Clear All).
The Supplier Group filter was displayed even when no supplier groups were present in the data.
The change that was made in the previous release (“Limiting the number of source locations could result in an unexpected infeasibility when small Capacity Consumed numbers were used, relative to the amount of products produced.”) could negatively impact the performance for some datasets.
In the release of February 10, 2025, the type of the column “sequence_order” was changed from string to int32. This was not in line with the documentation, and this new version will have the type changed back to “string”.
