SC Navigator 25.8.1
Date May 8, 2025
  • New Features
    • SC Navigator now allows you to create rate cards, that are both zonal based (using ‘Rate Card From’ & ‘Rate Card To’) and distance based (using ‘Distance Lower’ and ‘Distance Upper’). This allows for more flexible rate card modeling.
  • Improvements
    • If an invalid or missing Distance Unit of Measurement (UOM) is provided, ‘mile’ will be used as the default. The data validation has been updated to show an error when reading from Excel and a warning when reading from a dataset if the unit is not “km” or “mile”.
    • Data validation has been added to detect when a Base Case location has no inflow for a product.
    • The Whiteboard page has been updated to use a new internal mechanism for showing the details of the currently selected Whiteboard node or arc.
    • The Infeasibility Analysis page has been updated to use a new internal mechanism for showing the details of the infeasibilities. Previously you could determine which infeasibility details to show by selecting them in the top table of the page. In the new situation, this can be done in the two central widgets of the page by activating the relevant tabs on them.
  • Bug Fixes
    • When starting to solve a Center of Gravity model in the background, now a progress message is displayed, telling that the app is preparing for running it in the background.
    • When solving a Constrained Center of Gravity model, the capacities for fixed CoG locations were not calculated correctly when not all periods were included.
    • Timestamps in the SENSAI chat now accurately reflect your local time zone.
    • In some cases, the model was incorrectly identified as infeasible when the dataset contained data for attribute Base Case Minimum Capacity (sheet Transportation Type Product).
    • The Play function in the Period Selector could occasionally skip periods.
    • Previously, downloaded solutions and exported results incorrectly included both warehouse and production elements in both the Warehouse Definition and Production Definition tables. Now, each resource element is correctly placed in its respective table.
    • Spaces at the end of Custom Objective names are now removed from these names when generating the Excel template, to avoid related issues.
    • Previously, when two users were simultaneously using SC Navigator and one of them saved a result data visible for all users, then that result data would not show up for the other user before restarting the application session. This has been addressed, and the list of result datasets synchronizes correctly with the shared datasets when entering the Result Data dialog.
Be the first to reply!
