SC Navigator 26.13.1
Date November 19, 2026
New Features
New in SENSAI Pro:
You can ask it to load saved results and to choose which of them are compared side by side on the SC Navigator pages.
It can save your current data, including your changes, as a new input dataset. It validates the data first and never overwrites an existing dataset. See Save Input Data.
The new template sheets Custom Objective Period, Custom Objective Location and Custom Objective Transport let you set a Minimum Required and Maximum Allowed for a custom objective per period, in total, per location or per mode of transport. The limits are shown on the Control Panel, and you can change them there. An empty or 0 value means that there is no limit. For more information, see Custom Objective Period, Location and Transport Sheets.
Improvements
Several memory improvements have been made, making it less likely that sessions with large datasets run out of memory:
After a dataset has been imported, less memory stays in use for the rest of the session.
Loading a dataset while other data is already loaded now first releases the memory of the previous data.
For some large cases, the peak memory has been reduced, allowing for large models to be solved.
Large models with force-closed lanes, or with minimum capacities on lanes between warehouses, optimize faster and use less memory.
The infeasibility analysis now runs faster and uses less memory on large models when it allows missing lanes, or relaxes customer demand, supplier capacity or production capacity. Its outcome is unchanged.
Importing a dataset whose transport data uses product groups, for example in Transport Cost, now uses much less memory and time when there are many product groups. The values of a group are now only prepared for the lanes on which the dataset uses that group.
The data used by the Transport Scenario page is now only prepared when you open that page, instead of after every import and every time you switch to pages such as Data Issues, Circular Flows or Infeasibility Analysis. Sessions that do not use transport scenarios use less memory, and switching to these pages is faster on large datasets.
The documentation has been updated on a number of pages after an internal review of its status.
Results are kept when some products cost nothing to supply, produce or store. Instead of the “contact user support” error with no results, SC Navigator now shows the results with a warning that the plan may contain unnecessary volume or final stock. Giving supply, production and inventory a small cost avoids this.
Bug Fixes
With SC Navigator open in two browser tabs, opening the Load Data dialog, for example with Input Data on the status bar, could show “File Not Supported” straight away. It now shows “Upload Not Completed”, with a hint to close the other SC Navigator tab.
In rare circumstances, reading a data file into SC Navigator could empty the current session’s key needed to do the geocoding, leading to “Invalid key” messages.
With a penalty on Transportation Capacity, the infeasibility analysis could not exceed the Maximum # of Trips on lanes without a Minimum Capacity, Fixed Cost, Force Open or Maximum Capacity, and reported a customer demand violation instead. It can now exceed it on any lane, and shows the extra trips in the new Number of Trips Details table on the Infeasibility Analysis page.
