SC Navigator 26.7.1
Related products:SC Navigator
  • Jun 8, 2026 11:17 AM UTC
  • 28 views
SC Navigator 26.7.1
Date June 8, 2026
  • New Features
    • There are two new attributes on the Production Routing sheet: Minimum Open and Maximum Open. This allows for adding a new type of count constraint to the model. You can now enforce how many production routing combinations must be active within a group.
    • These new Minimum Open and Maximum Open attributes are also included in the Full Solution Export on sheet Production BOM.
  • Improvements
    • On the Transport Navigator map, the displayed routes are now colored differently to make it easier to distinguish them. Furthermore, when clicking on one of those routes, it gets highlighted such that it stands out clearly from the other routes.
    • SENSAI switched to a more powerful model; it understands you better and it responds faster.
    • The multilingual support is improved such that SENSAI always answers in the language of the question asked.
    • SENSAI Pro now supports copying data between warehouses.
    • The SENSAI History Filter button has been improved with a consistent icon, stable button size, and a clearer filtered state indicator.
  • Bug Fixes
    • In Transport Navigator, if Maximum Layover Duration was not specified, the Maximum Layover Duration would be set to 0 instead of being unlimited.
    • In SENSAI Pro, a warehouse created from scratch was missing internal flags, which could cause incorrect behavior.
    • In SENSAI Pro, copying a warehouse now correctly transfers all related data to the new warehouse.
    • Undo in SENSAI Pro now correctly reverts all affected attributes (e.g. Force Open, Force Close) when making changes.
    • In the maximized view, a widget without header could cause the navigation to get stuck in the maximized view.
    • In the Full Solution Export, when using the same resource ID for both Production and Warehouse entries, the Production sheet could get missing. Production data is now correctly preserved in the generated Excel file.
    • The Full Solution Export now includes Take or Pay Unit and Take or Pay Cost in the Transport Results sheet.
