Error message: Main project is not an existing folder
  • Apr 9, 2022 1:17 AM UTC
  • 281 views
When trying to open the aimms file I get the Error message: Main project is not an existing folder. It is from a Zipfile, normal Folder works. Indentical files. What is the error here?
Best answer by MarcelRoelofs
What happens if you open a file directly from a zipfile, is that Windows will unpack that file to a temporary location and will open that file. When AIMMS opens such a temporarily unpacked .aimms file, it also wants to open additional files from the MainProject folder. These are not unpacked by Windows, however, hence opening an AIMMS project directly from a zip file will fail.
So, I think the error here is that direct access to zip files in Windows Explorer give a false sense that all files in the zip file will be directly accessible, which they are not, unless you unpack the zip file.
I get the error, if I send the zipfile and open the AIMMS File which weirdly has only 1 KB, the main project doesn’t exist… please help me solve this hell task
  • Apr 11, 2022 8:42 AM UTC
I get the same error if I try to open an .aimms file in a compressed folder. I think the problem is that you should first unpack the folder again before you can open the model.
MarcelRoelofs
  • Apr 11, 2022 10:39 AM UTC
