How to create a new set which is a transformation of a previous set
  • Apr 1, 2025 9:22 AM UTC
  • 89 views
Basically ill provide here the formulation:
We have set t →       t ∈ T = {1,2,...,tn}           ∀t ∈ T
And we need to create and use set tau where tau stands for
tau →      ∀τ =t+1,...,min(t+Li −1,tn)
Please, it would be so helpful if someone could provide a solution. Thank you so much.
Best answer by luispinto
Hello!
If I understand correctly, the first set is easy to define.
Having a parameter tn and then having a set defined as {1..tn} would do the trick. You may want to put a condition in the definition, something like
If tn >= 1 then
{1..tn}
endif;
To avoid getting errors when tn is < 1.
For the second one, I am not sure if I fully understand. Do you have an indexed set? Which t are you referring to when you mention  ∀τ =t+1,...,min(t+Li −1,tn)? Since t is an index of a set, it is variable, not a fixed parameter.
Maybe a parameter could do the trick, something like:
tau(t1,t2)
defined as
if t2 > t1 and t2 < min(t + Li - 1,tn) then 1 endif;
Assuming Li is a parameter.
This is the code I played around with:
Parameter tn;
Parameter Li;
Set sT {
    SubsetOf: Integers;
    Index: t, t1, t2;
    Property: ElementsAreNumerical;
    Definition: {
        if tn >= 1 then
            {1..tn}
        endif;
Parameter Tau {
    IndexDomain: (t1,t2);
    Definition: {
        if t2 > t1 and t2 < min(t1 + Li - 1,tn) then 1 endif;
And using tn = 10; Li = 5; I would get:
Hope it helps.
luispinto
  • Customer Success Manager
  • Apr 3, 2025 8:25 AM UTC
Hello!
If tn >= 1 then
{1..tn}
endif;
tau(t1,t2)
defined as
Parameter tn;
Parameter Li;
Set sT {
    SubsetOf: Integers;
    Index: t, t1, t2;
    Definition: {
        if tn >= 1 then
            {1..tn}
        endif;
Parameter Tau {
    Definition: {
Hope it helps.
