if else then else condition as constraint/variable, multi-objective optimisation, robust/stochastic optimisation
  • Jun 12, 2023 2:29 PM UTC
  • 108 views
Dear AIMMS team,
I trust this meets you well. Thank you for all your support. My challenge is multifaceted.
I am building AIMMS code to optimize hybrid energy system just as it is presented in the 'calc' sheet of the attached Excel file. The two AIMMS folders attached show how I have attempted to reproduce the 'calc sheet' functions in AIMMS, but below are the comments from AIMMS after running them:
''The definition of constraint 'Constraint_2(01)' contains an if-then-else statement with a variable in the condition, which cannot be handled by OCTERACT.''
''The definition of constraint 'Positive_Energy_Difference_kW_definition(01)' contains an if-then-else statement with a variable in the condition, which cannot be handled by OCTERACT.''
All the column functions (in Excel 'calc' tab) are represented in AIMMS. It appears the way I have written the conditional statements in the two AIMMS folders is not allowed. Kindly assist further.
Please note: The AIMMS data file for both AIMMS folders that should be loaded into active is 'Testing.data'.
I will like to ask two more questions about the challenge I have shared above.
1. If I want to perform multi-objective optimization (two objectives), do I have to add another aimms variable and mathematical program to contain the second objective, or do I add it to the aimms variable containing the first objective but with weighting factors? Please help I need clarification on how to use AIMMs to perform multi-objective optimization.
2. In the case of introducing uncertainty to three parameters (Load(t), windspeed(t) and Solar_Irradiation_Wperm2(t)) in order to perform stochastic optimization and robust optimization, in what way can this be carried out?
I will also appreciate any comprehensive material I can use to gain more understanding.
Thank you so much.
