Reading excel data
  • Mar 31, 2020 8:41 AM UTC
  • 253 views
I have built my first AIMMS model and it is running without any errors now. However, it does not read my excel data and therefore I do not get any result. I was wondering what could be the problem. Do I need to save the project and the input excel sheet in the same folder?
Thank you very much in advance!
Best answer by Max Lomba Vrouenraets
Hi @mateusarakawa,
First of all, thank you very much for your help! I truly appreciate it!
Nevertheless, AIMMS was not reading my excel sheet because I had not saved it in the proper folder. Once I changed the location of the document to the proper folder, AIMMS started reading the input data @Andrew.
Again, thank you!
mateusarakawa
Hi, @Max Lomba Vrouenraets . I can’t see in your code, where you are reading the values from the excel.
For instance, you can use some of these functions in order to read excel data:
AIMMS Functions to read Excel data
Andrew
  • Apr 6, 2020 7:41 PM UTC
Hi @Max Lomba Vrouenraets
Did mateus’s answer help you with your problem?
Thanks
Hi @mateusarakawa,
Again, thank you!
  • Apr 16, 2020 7:37 PM UTC
I had problems at the beginning with XLSX. I think it has to be in XLS Filetype and not XLSX.
