Robust Optimization
  • May 26, 2020 4:54 PM UTC
  • 291 views
After building a deterministic model, I constructed the robust counterpart of the model. I defined an uncertain parameter and I called the GMP  GenerateRobustCounterpart. The model seems to be running without errors,however, it does not provide any result. It seems like the variable (vAllcocationFlow) does not get filled. Can someone help me with this?
I attach you here the Solve function (1) and the uncertain parameter definition (2):
Thank you very much in advance!
Best answer by Max Lomba Vrouenraets
Hi @Marcel Hunting,
Thank you very much for your response. I was finally able to solve the problem. I needed to add the GMP function GenerateRobustCounterpart into the for-loop.
Thank you!
Hi @Max Lomba Vrouenraets We need a bit more information to help you with your question. Would it be possible for you to add your project here, preferably after adding it to a zip file, or send it to our support by email if your project contains sensitive information?
Hi @Marcel Hunting,
Thank you!
