Scope of index j has not been specified
Hi!
I am trying to create a vehicle routing problem in aimms. However, i am encountering a problem in Constraint4 (as shown below). The arcs are the arrows in a graph to every customer with a certain demand. I have tried different index domains, but none of them successful. Does anyone know how to fix this?
Thanks in advance.
Chris Kuip
Perhaps the definition should read:
sum( i, f(i,k) ) - sum( j, f(k,j) ) = q(k)
  • May 9, 2022
Thanks for your reaction. If I try this, I get the message: The index ‘k’ does not denote a subset of the set “Arcs”.
Chris Kuip
May I ask:
  1. I seem to missing the set Nodes, is that correct?
  2. Which set is the range of the indices i, j, and k respectively?
  3. How is the set arcs declared, as a subset of Nodes X Nodes?
  4. Is customers a subset of Nodes?
