Warning: Model status 13: Error no solution, Solver status 9: Error: Setup failure (see message window).
  • Aug 22, 2022 8:54 AM UTC
  • 285 views
Hello everyone,
Trust you are doing well?
I am presently working on an academic research that involves optimal sizing of energy systems using AIMMS academic license.
I have the message in bold print below displayed on the warning bar while the picture attached is the snapshot of the progress window.
Kindly support.
Hi @Lawrence. The Message Window will likely show that your QCP model is non-convex. To solve non-convex QCP models with CPLEX you have to set the CPLEX option ‘Solution target’ to ‘Search for global optimum’.
  • Aug 22, 2022 1:38 PM UTC
Thank you Marcel,
I did but still giving error message.
Warning: Model status 13: Error no solution, Solver status 9: Error: Setup failure.
Warning at line 1 in user-defined function section "MainExecution":
CPLEX error: CPLEX cannot handle QCP models with quadratic equality constraints like 'Zero_Constraint(01)'
Thank you.
Sorry, my mistake. CPLEX cannot handle non-convex QCP models (but it can handle non-convex QP models, after setting the ‘Solution target’ option). A quadratic equality constraint makes the model non-convex.
The solver Gurobi can handle non-convex QCP models but running Gurobi in AIMMS is a bit more hassle because you have to request a Gurobi license from Gurobi Optimization (free for academics). Please note that to solve a non-convex QCP (or QP) you have to set the Gurobi option ‘Nonconvex strategy’ to ‘Translate’.
An alternative is Octeract, which is a global nonlinear solver. Octeract is available as part of the free AIMMS Academic License.
